Farberware FSTO100 Power Supply Replacement
  1. Farberware FSTO100 Power Supply Replacement, Power Supply: step 1, image 1 of 1
    • Make sure the toaster is unplugged.
    • First, to remove the plastic bracket, turn toaster oven on its side.
  2. Farberware FSTO100 Power Supply Replacement: step 2, image 1 of 1
    • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  3. Farberware FSTO100 Power Supply Replacement: step 3, image 1 of 1
    • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  4. Farberware FSTO100 Power Supply Replacement: step 4, image 1 of 1
    • If the wire gets pulled out of the transformer, reinsert it.
    • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Tony Wang
103 Reputation
5 Guides authored
Cal Poly, Team 6-35, Regan Fall 2012 Member of Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,436
