Introduction
The color filter in front of the camera (under the lens) had come loose.
This resulted in the image partly having a strong green tint.
Teardown of the camera with reattaching the color filter. Many webcams seem to have a similar design, so this guide might be helpful to others.
To replace the lens, perform step 5 instead of step 4.
Place the color filter (shown as shimmering red and transparent in the picture) back in its intended position. I've also applied a little extra glue to the corners, but this isn't absolutely necessary.
ATTENTION: Any dirt will be visible in the camera image!
The second picture shows the camera.
The webcam can now be reassembled.
I unnecessarily removed the lens. In case someone needs to replace it:
First, unscrew the silver ring. This is glued to the actual lens, but can be easily removed.
The lens itself is also slightly glued and can be unscrewed.
During reassembly, I recommend connecting the camera to a computer to see when the image is sharp.
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
