Fast Fix Peloton Bike+ Seat & Slider Replacement
AlexCR
AlexCR and one other contributor
Last updated on December 13, 2023
10 - 15 minutes
Moderate
Introduction
Go to step 1
This guide will show the procedure on how to completely replace the bike seat and seat slider on the Peloton Bike+ by removing the seat and slider, and replacing it with a new one. It is a fairly simple process that people with little to no experience in repairing things should be able to do.
Note: This guide is for the Peloton Bike+, not the base Peloton Bike. Both bikes are similar, but some mechanisms are a bit different.
If there are other issues with your bike, the Peloton Support Page contains much repair information that may be useful to you.
The tools needed for this guide are included in the toolkit that comes with the Peloton bike. Those tools are:
  • A 13mm Wrench
  • A 3mm Allen Wrench
Now lets get fixing shall we?
  1. Fast Fix Peloton Bike+ Seat & Slider Replacement, Peloton Bike+ Seat & Slider: step 1, image 1 of 1
    • Remove any weights or other items from the weight holders. Also, make sure there is nothing on the bike seat itself.
  2. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 2, image 1 of 1
    • Make note of the seat depth setting on the seat slider & seat rails so it can be set back on those settings when we install the replacement seat.
    • Take a close up picture similar to the one shown here, and once we put the new seat in place, look back at the picture and align the new seat to the position shown in the original image.
  3. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 3, image 1 of 2 Fast Fix Peloton Bike+ Seat & Slider Replacement: step 3, image 2 of 2
    • Use the 13mm wrench to loosen one or both of the seat nuts until the seat is removed.
    • The nuts themselves do not come off! Simply loosen them until the seat can be gently wiggled off of the seat slider.
  4. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 4, image 1 of 1
    • Using the 3mm allen wrench, remove the 4 weight holder screws, and remove the weight holder itself. There are 2 screws on each side of the weight holder.
  5. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 5, image 1 of 1
    • Open the latch on the seat slider, but do not slide it off yet.
  6. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 6, image 1 of 1
    • Remove the screw and washer from the seat post end with the 3mm allen wrench.
    • Do this by gently unscrewing the screw from inside the washer, and then removing both once it is loose enough to gently pull out of the socket.
  7. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 7, image 1 of 3 Fast Fix Peloton Bike+ Seat & Slider Replacement: step 7, image 2 of 3 Fast Fix Peloton Bike+ Seat & Slider Replacement: step 7, image 3 of 3
    • Slide the seat slider off of the seat post and slide on the new seat slider in its place. Do not close the latch just yet!
  8. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 8, image 1 of 2 Fast Fix Peloton Bike+ Seat & Slider Replacement: step 8, image 2 of 2
    • Re-install the screw and washer onto the seat post end with the 3mm allen wrench, then close the latch on the seat slider.
    • You may slide the seat slider into whatever position you desire. Just remember that you can always adjust the position of it after the full replacement is complete.
  9. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 9, image 1 of 1
    • Re-install the weight holder and its associated screws with the 3mm allen wrench.
  10. Fast Fix Peloton Bike+ Seat & Slider Replacement: step 10, image 1 of 2 Fast Fix Peloton Bike+ Seat & Slider Replacement: step 10, image 2 of 2
    • Finally, install the replacement seat and nuts with the 13mm wrench, aligning with the previously noted depth settings.
    • Remember to double check that the seat itself is not loose or wobbly, make sure it is stern and securely in place to prevent injuries when sitting on it.
If you notice anything off with the new bike seat and slider, make sure that everything is secure and all screws/nuts are tight. If you still notice issues, simply follow the guide again, but do not replace any parts with new parts, just remove and replace those same parts.
AlexCR
181 Reputation
1 Guide authored
One Comment
I need a seat slider can you sell too me ?
Conrado Zapata - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 66
All Time: 1,578
