Fast Fix Shower Curtain Permanent Rod Replacement
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: step 1, image 1 of 1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: step 2, image 1 of 2 Fast Fix Shower Curtain Permanent Rod Replacement: step 2, image 2 of 2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: step 3, image 1 of 1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: step 4, image 1 of 1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: step 5, image 1 of 1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: step 6, image 1 of 2 Fast Fix Shower Curtain Permanent Rod Replacement: step 6, image 2 of 2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
To reassemble your device, follow these instructions in reverse order
2 other people completed this guide.
Abdul-Jabbar Mohamed
161 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 848
