Faucet Stem Replacement
  1. Faucet Stem Replacement, Stem: step 1, image 1 of 1
    • Turn off the water supply.
  2. Faucet Stem Replacement: step 2, image 1 of 1
    • Pry off the faucet cap with a spudger.
  3. Faucet Stem Replacement: step 3, image 1 of 1
    • Unscrew the knob with either a Phillips or a flathead screwdriver, depending on your faucet.
    • Remove the knob from the faucet.
  4. Faucet Stem Replacement: step 4, image 1 of 1
    • Use a wrench to remove the nut from the faucet stem.
  5. Faucet Stem Replacement: step 5, image 1 of 1
    • Remove the faucet stem using pliers.
    • Removing the stem can be very difficult so make sure you are stable and have control.
  6. Faucet Stem Replacement: step 6, image 1 of 1
    • Use a paper towel to soak up any excess water in the area where the stem was located.
  7. Faucet Stem Replacement: step 7, image 1 of 1
    • To replace the new stem, simply push it down into the hole.
  8. Faucet Stem Replacement: step 8, image 1 of 2 Faucet Stem Replacement: step 8, image 2 of 2
    • When the stem is installed, screw in the nut over the stem with pliers.
  9. Faucet Stem Replacement: step 9, image 1 of 1
    • Apply the knob and screw into the stem.
  10. Faucet Stem Replacement: step 10, image 1 of 1
    • Lastly, Turn the water supply back on and watch the magic happen!
I hope this guide was simple and easy to follow. If you have any questions, feel free to leave a comment below, and I'll get back to you as soon as possible.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 73
All Time: 1,018
