Fender '65 Tube Amp Speaker Replacement
  1. Fender '65 Tube Amp Speaker Replacement, Speaker: step 1, image 1 of 1
    • Lay the amplifier face-down.
  2. Fender '65 Tube Amp Speaker Replacement: step 2, image 1 of 1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender '65 Tube Amp Speaker Replacement: step 3, image 1 of 2 Fender '65 Tube Amp Speaker Replacement: step 3, image 2 of 2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender '65 Tube Amp Speaker Replacement: step 4, image 1 of 3 Fender '65 Tube Amp Speaker Replacement: step 4, image 2 of 3 Fender '65 Tube Amp Speaker Replacement: step 4, image 3 of 3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender '65 Tube Amp Speaker Replacement: step 5, image 1 of 1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender '65 Tube Amp Speaker Replacement: step 6, image 1 of 3 Fender '65 Tube Amp Speaker Replacement: step 6, image 2 of 3 Fender '65 Tube Amp Speaker Replacement: step 6, image 3 of 3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender '65 Tube Amp Speaker Replacement: step 7, image 1 of 3 Fender '65 Tube Amp Speaker Replacement: step 7, image 2 of 3 Fender '65 Tube Amp Speaker Replacement: step 7, image 3 of 3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 60
