Fender Frontman 15r Fuse Replacement
  1. Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 1 of 3 Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 2 of 3 Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 3 of 3
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
  2. Fender Frontman 15r Fuse Replacement: step 2, image 1 of 2 Fender Frontman 15r Fuse Replacement: step 2, image 2 of 2
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
Stephen Figueira
151 Reputation
3 Guides authored
Cal Poly, Team 24-30, Regan Fall 2012 Member of Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 41
All Time: 14,335
