Fender Starcaster String Removement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Fender Starcaster String Removement, Loosen the Strings: step 1, image 1 of 3 Fender Starcaster String Removement, Loosen the Strings: step 1, image 2 of 3 Fender Starcaster String Removement, Loosen the Strings: step 1, image 3 of 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: step 2, image 1 of 2 Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: step 2, image 2 of 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 1 of 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 2 of 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 3 of 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Finish Line
Christopher Hartigan
164 Reputation
5 Guides authored
Pasco Hernando, Team 5-3, Prince Fall 2014 Member of Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,380
