Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: step 1, image 1 of 1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 2, image 1 of 1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 3, image 1 of 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 3, image 2 of 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 3, image 3 of 3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 4, image 1 of 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 4, image 2 of 2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 5, image 1 of 1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 6, image 1 of 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 6, image 2 of 2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 7, image 1 of 1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 8, image 1 of 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: step 8, image 2 of 2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Giancarlo Marruffo
2 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,160
