Introduction
If the amplifier is not turning on when you press the power switch, you may want to replace the batteries. Each 9-volt battery provides power to the amplifier. It is crucial to have good batteries to enhance functionality of your amplifier.
Press the bottom tab and lift the lid that is marked "9V Battery"
Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
Insert a new, fully-charged 9-volt battery to the terminal connections.
Link the positive terminal (+) of the 9-volt battery to the positive connection.
Link the negative terminal (-) of the 9-volt battery to the negative connection.
Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
