Fisher Paykel Neopuff Valve System Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Fisher Paykel Neopuff Valve System Replacement, Valve System: step 1, image 1 of 1
    • Remove the back cover, fixed by four screws.
    • Disconnect the tube from the manometer.
    • Remove the manometer by unscrewing the two retaining nuts.
    • Fit the existing manometer into the new valve assembly panel.
    • Tighten the retaining nuts.
    • Reconnect the manometer tube.
    • Refit the front panel to the back cover with the four screws from step 1.
  2. Fisher Paykel Neopuff Valve System Replacement: step 8, image 1 of 1
    • Carry out the valve system performance test described above. It is recommended to record the lot number of the new valve assembly onto the Set-up and Maintenance Checklist.
Constantine Yap
364 Reputation
2 Guides authored
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
4 Members
27 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 231
