Fitbit Blaze Display Frame Replacement
  1. Fitbit Blaze Display Frame Replacement, Wristband: step 1, image 1 of 2 Fitbit Blaze Display Frame Replacement, Wristband: step 1, image 2 of 2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Display Frame Replacement: step 2, image 1 of 1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Display Frame Replacement: step 3, image 1 of 3 Fitbit Blaze Display Frame Replacement: step 3, image 2 of 3 Fitbit Blaze Display Frame Replacement: step 3, image 3 of 3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Display Frame Replacement, Display Frame: step 4, image 1 of 3 Fitbit Blaze Display Frame Replacement, Display Frame: step 4, image 2 of 3 Fitbit Blaze Display Frame Replacement, Display Frame: step 4, image 3 of 3
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
3 other people completed this guide.
Adrian Borrego
2,242 Reputation
5 Guides authored
USF Tampa, Team S3-G3, Sullivan Spring 2017 Member of USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 11,288
