Fitbit Charge HR Screen Replacement
  1. Fitbit Charge HR Screen Replacement, Screen: step 1, image 1 of 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Screen Replacement: step 2, image 1 of 3 Fitbit Charge HR Screen Replacement: step 2, image 2 of 3 Fitbit Charge HR Screen Replacement: step 2, image 3 of 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Screen Replacement: step 3, image 1 of 2 Fitbit Charge HR Screen Replacement: step 3, image 2 of 2
    • Remove the motherboard assembly from the device.
    • Flip the motherboard over so the screen is facing upwards.
  4. Fitbit Charge HR Screen Replacement: step 4, image 1 of 3 Fitbit Charge HR Screen Replacement: step 4, image 2 of 3 Fitbit Charge HR Screen Replacement: step 4, image 3 of 3
    • Wedge a nylon spudger between the screen and the motherboard.
    • Gently pry the screen up and remove it from the motherboard.
    • Metal spudgers can puncture an unprotected battery and damage components like the motherboard. Always choose a tool that's ESD-safe, such as a nylon spudger or plastic opening tool.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 990
