Fitbit Charge HR Vibration Motor Replacement
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: step 1, image 1 of 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: step 2, image 1 of 3 Fitbit Charge HR Vibration Motor Replacement: step 2, image 2 of 3 Fitbit Charge HR Vibration Motor Replacement: step 2, image 3 of 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: step 3, image 1 of 1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: step 4, image 1 of 2 Fitbit Charge HR Vibration Motor Replacement: step 4, image 2 of 2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 438
