Fitbit Surge GPS Replacement
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: step 1, image 1 of 2 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: step 1, image 2 of 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: step 2, image 1 of 3 Fitbit Surge GPS Replacement: step 2, image 2 of 3 Fitbit Surge GPS Replacement: step 2, image 3 of 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: step 3, image 1 of 2 Fitbit Surge GPS Replacement: step 3, image 2 of 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: step 4, image 1 of 2 Fitbit Surge GPS Replacement: step 4, image 2 of 2
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 other people completed this guide.
Angela Pitts
1,190 Reputation
4 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2016 Member of USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 Members
4 Guides authored
1 Guide Comment
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 3,089
