Fix a Loose Mounting Dream MD2462 TV Wall Mount
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 1, image 1 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 1, image 2 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 1, image 3 of 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 2, image 1 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 2, image 2 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 2, image 3 of 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 3, image 1 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 3, image 2 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 3, image 3 of 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 4, image 1 of 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 5, image 1 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 5, image 2 of 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 5, image 3 of 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 6, image 1 of 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 6, image 2 of 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 7, image 1 of 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 7, image 2 of 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: step 8, image 1 of 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Emmanuel Emedeke
184 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 5,113
