Fix rattling sound inside Tapco Link
  1. Fix rattling sound inside Tapco Link, Introduction: step 1, image 1 of 1
    • Put the device in front of you, with the knob labels the right side up
  2. Fix rattling sound inside Tapco Link, Revealing Screws: step 2, image 1 of 2 Fix rattling sound inside Tapco Link, Revealing Screws: step 2, image 2 of 2
    • Pry the rubber off the top of the device
    • All the rubber
    • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
    • 5 screw holes will appear. Leave them alone for now.
  3. Fix rattling sound inside Tapco Link: step 3, image 1 of 2 Fix rattling sound inside Tapco Link: step 3, image 2 of 2
    • Look at the side of the device with the metal stand
    • Take a heat gun to the two small foam pads
    • You only need to pry off the halves on the top plastic shell
    • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
    • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
  4. Fix rattling sound inside Tapco Link: step 4, image 1 of 2 Fix rattling sound inside Tapco Link: step 4, image 2 of 2
    • Now remove the 5 Philips screws on top
  5. Fix rattling sound inside Tapco Link: step 5, image 1 of 1
    • Simply lift off the top
    • No clips anywhere
  6. Fix rattling sound inside Tapco Link: step 6, image 1 of 1
    • You could now lift out the whole innards
    • They are not attached to the bottom shell
    • No, the mess of glue is how it left the factory
  7. Fix rattling sound inside Tapco Link, Fix rattling sound inside Tapco Link: step 7, image 1 of 1
    • Look for a small metal rectangle with a hole
    • It's supposed to give a Kensington lock a better hold than the thin backplate
    • It's insufficiently glued on
Tobias
10 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 248
