Fixed Gear Bike Chainring Replacement
  1. Fixed Gear Bike Chainring Replacement, Chainring: step 1, image 1 of 2 Fixed Gear Bike Chainring Replacement, Chainring: step 1, image 2 of 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: step 2, image 1 of 2 Fixed Gear Bike Chainring Replacement: step 2, image 2 of 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: step 3, image 1 of 2 Fixed Gear Bike Chainring Replacement: step 3, image 2 of 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: step 4, image 1 of 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: step 5, image 1 of 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Finish Line
aljndro__
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 642
