Flip MinoHD Casing Replacement
  1. Flip MinoHD Casing Replacement, Casing: step 1, image 1 of 2 Flip MinoHD Casing Replacement, Casing: step 1, image 2 of 2
    • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
    • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
  2. Flip MinoHD Casing Replacement: step 2, image 1 of 2 Flip MinoHD Casing Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
    • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
    • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 767
