Flip Ultra HD USB Latch Spring Replacement
  1. Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: step 1, image 1 of 3 Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: step 1, image 2 of 3 Flip Ultra HD USB Latch Spring Replacement, USB Latch Spring: step 1, image 3 of 3
    • Here is the Flip Ultra HD and it shows lots of use.
    • The USB latch does not return to the upright position when the USB arm is retracted.
    • Slide the battery latch to unlock
  2. Flip Ultra HD USB Latch Spring Replacement: step 2, image 1 of 3 Flip Ultra HD USB Latch Spring Replacement: step 2, image 2 of 3 Flip Ultra HD USB Latch Spring Replacement: step 2, image 3 of 3
    • Slide the front panel down and up to remove.
    • Remove the battery by pulling up on the tab
    • Peel the identification sticker back about half way.
  3. Flip Ultra HD USB Latch Spring Replacement: step 3, image 1 of 2 Flip Ultra HD USB Latch Spring Replacement: step 3, image 2 of 2
    • Beneath the sticker is a rectangular opening that houses the spring for the USB latch return. In this case it is clearly broken
    • Use a pair of Needle Nose Pliers to remove and replace the spring
oldturkey03
839,563 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 1,105
