Flip Video Ultra Camera lense Replacement
  1. Flip Video Ultra Camera lense Replacement, Circuit Board: step 1, image 1 of 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Camera lense Replacement: step 2, image 1 of 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Camera lense Replacement: step 3, image 1 of 1
    • Remove the batteries
  4. Flip Video Ultra Camera lense Replacement: step 4, image 1 of 1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Camera lense Replacement: step 5, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 5, image 2 of 2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Camera lense Replacement: step 6, image 1 of 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Camera lense Replacement: step 7, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 7, image 2 of 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Camera lense Replacement: step 8, image 1 of 1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Camera lense Replacement: step 9, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 9, image 2 of 2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Camera lense Replacement: step 10, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 10, image 2 of 2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Camera lense Replacement: step 11, image 1 of 1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Camera lense Replacement: step 12, image 1 of 3 Flip Video Ultra Camera lense Replacement: step 12, image 2 of 3 Flip Video Ultra Camera lense Replacement: step 12, image 3 of 3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Camera lense Replacement: step 13, image 1 of 1
    • Unscrew the camera housing unit from the plastic case.
  14. Flip Video Ultra Camera lense Replacement: step 14, image 1 of 3 Flip Video Ultra Camera lense Replacement: step 14, image 2 of 3 Flip Video Ultra Camera lense Replacement: step 14, image 3 of 3
    Tool used on this step:
    Buy
    • With tweezers, remove the microphone and USB connections.
  15. Flip Video Ultra Camera lense Replacement: step 15, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 15, image 2 of 2
    • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
  16. Flip Video Ultra Camera lense Replacement: step 16, image 1 of 2 Flip Video Ultra Camera lense Replacement: step 16, image 2 of 2
    • Remove the single 2.1 mm screw and separate camera from the circuit board.
  17. Flip Video Ultra Camera lense Replacement, Camera lense: step 17, image 1 of 1
    • Camera lens is now separated from the circuit board.
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 339
