Flip Video Ultra USB Spring Replacement
  1. Flip Video Ultra USB Spring Replacement, USB spring: step 1, image 1 of 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra USB Spring Replacement: step 2, image 1 of 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra USB Spring Replacement: step 3, image 1 of 1
    • Remove the batteries
  4. Flip Video Ultra USB Spring Replacement: step 4, image 1 of 1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra USB Spring Replacement: step 5, image 1 of 2 Flip Video Ultra USB Spring Replacement: step 5, image 2 of 2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra USB Spring Replacement: step 6, image 1 of 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra USB Spring Replacement: step 7, image 1 of 2 Flip Video Ultra USB Spring Replacement: step 7, image 2 of 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra USB Spring Replacement: step 8, image 1 of 1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra USB Spring Replacement: step 9, image 1 of 1
    • Using the Phillips head screwdriver, disconnect spring from the plastic nubs.
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 214
