Flip Video Ultra USB connector Replacement
  1. Flip Video Ultra USB connector Replacement, USB connector: step 1, image 1 of 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra USB connector Replacement: step 2, image 1 of 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra USB connector Replacement: step 3, image 1 of 1
    • Remove the batteries.
  4. Flip Video Ultra USB connector Replacement: step 4, image 1 of 1
    • Slide the black upper casing off from the device.
    • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
  5. Flip Video Ultra USB connector Replacement: step 5, image 1 of 2 Flip Video Ultra USB connector Replacement: step 5, image 2 of 2
    • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
  6. Flip Video Ultra USB connector Replacement: step 6, image 1 of 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra USB connector Replacement: step 7, image 1 of 2 Flip Video Ultra USB connector Replacement: step 7, image 2 of 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra USB connector Replacement: step 8, image 1 of 2 Flip Video Ultra USB connector Replacement: step 8, image 2 of 2
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra USB connector Replacement: step 9, image 1 of 2 Flip Video Ultra USB connector Replacement: step 9, image 2 of 2
    • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
  10. Flip Video Ultra USB connector Replacement: step 10, image 1 of 2 Flip Video Ultra USB connector Replacement: step 10, image 2 of 2
    Tool used on this step:
    Buy
    • Gently lift the usb connector using the Plastic opening tool.
    • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
    • The connector will be easier to remove if you wiggle the tweezers while lifting.
  11. Flip Video Ultra USB connector Replacement: step 11, image 1 of 1
    • Fully remove the USB connector and replace it with the new USB connector.
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
10 Guides authored
2 Guide Comments
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Reply
Where do you purchase the replacement usb connector?
DeEtte Moore - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,388
