Flipper Zero iButton board Replacement
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero iButton board Replacement, Remove the microSD card: step 2, image 1 of 1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero iButton board Replacement, Remove the screws: step 3, image 1 of 1
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero iButton board Replacement, Open the back cover: step 4, image 1 of 3 Flipper Zero iButton board Replacement, Open the back cover: step 4, image 2 of 3 Flipper Zero iButton board Replacement, Open the back cover: step 4, image 3 of 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: step 5, image 1 of 2 Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: step 5, image 2 of 2
    $5.49
    Buy
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero iButton board Replacement, Disconnect the battery: step 6, image 1 of 1
    Spudger
    $3.99
    Buy
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero iButton board Replacement, Disconnect the ribbon cable: step 7, image 1 of 2 Flipper Zero iButton board Replacement, Disconnect the ribbon cable: step 7, image 2 of 2
    iFixit Opening Picks (Set of 6)
    Buy
    • Disconnect the small ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero iButton board Replacement, Remove the iButton board: step 8, image 1 of 2 Flipper Zero iButton board Replacement, Remove the iButton board: step 8, image 2 of 2
    $5.49
    Buy
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
    • Once the screw is removed, carefully remove the iButton board.
  8. Flipper Zero iButton board Replacement, Remove the cable from the iButton board: step 9, image 1 of 2 Flipper Zero iButton board Replacement, Remove the cable from the iButton board: step 9, image 2 of 2
    Spudger
    $3.99
    Buy
    • To disconnect the flat cable from the iButton board, use a Spudger to carefully release the lock by pulling the latch up.
    • Once the connector is unlocked, gently pull the cable out of the connector.
Sebastian
31,321 Reputation
71 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 11
Past 30 Days: 50
All Time: 1,919
