Foldable Grocery Cart Wheels Replacement
  1. Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 1 of 3 Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 2 of 3 Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 3 of 3
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
  2. Foldable Grocery Cart Wheels Replacement: step 2, image 1 of 2 Foldable Grocery Cart Wheels Replacement: step 2, image 2 of 2
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: step 3, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 3, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 3, image 3 of 3
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: step 4, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 4, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 4, image 3 of 3
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: step 5, image 1 of 2 Foldable Grocery Cart Wheels Replacement: step 5, image 2 of 2
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
  6. Foldable Grocery Cart Wheels Replacement: step 6, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 6, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 6, image 3 of 3
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: step 7, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 7, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 7, image 3 of 3
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: step 8, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 8, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 8, image 3 of 3
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: step 9, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 9, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 9, image 3 of 3
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
  10. Foldable Grocery Cart Wheels Replacement: step 10, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 10, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 10, image 3 of 3
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
2 other people completed this guide.
Saba Aafreen
232 Reputation
1 Guide authored
One Comment
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Reply
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 263
All Time: 8,902
