Ford Mustang Thermostat Replacement
  1. Ford Mustang Thermostat Replacement, Pop the hood: step 1, image 1 of 1
    • Make sure the car is turned off.
  2. Ford Mustang Thermostat Replacement, Unscrew and disconnect the marked bolts/hoses.: step 2, image 1 of 2 Ford Mustang Thermostat Replacement, Unscrew and disconnect the marked bolts/hoses.: step 2, image 2 of 2
    • Take the cold air intake out as a whole.
  3. Ford Mustang Thermostat Replacement, Unscrew the labeled hose clamp in order to remove the cold air intake.: step 3, image 1 of 2 Ford Mustang Thermostat Replacement, Unscrew the labeled hose clamp in order to remove the cold air intake.: step 3, image 2 of 2
    • The second picture is what it should look like once you remove the cold air intake. The thermostat is located by the blue box.
  4. Ford Mustang Thermostat Replacement, After locating the thermostat housing, use a channel lock to unclip the hose clamp.: step 4, image 1 of 2 Ford Mustang Thermostat Replacement, After locating the thermostat housing, use a channel lock to unclip the hose clamp.: step 4, image 2 of 2
    • When you remove the hose, make sure and keep it tilted upright so that you don't leak any antifreeze. The second image shows how you should do this.
  5. Ford Mustang Thermostat Replacement, Using a 1/4 inch ratchet with a 8mm socket, unscrew the two shown bolts on the thermostat housing.: step 5, image 1 of 2 Ford Mustang Thermostat Replacement, Using a 1/4 inch ratchet with a 8mm socket, unscrew the two shown bolts on the thermostat housing.: step 5, image 2 of 2
    • Remove the housing cover to see the thermostat. The second image shows this.
  6. Ford Mustang Thermostat Replacement, Remove the hose underneath the thermostat to release the pressure so you can easily take out the thermostat.: step 6, image 1 of 2 Ford Mustang Thermostat Replacement, Remove the hose underneath the thermostat to release the pressure so you can easily take out the thermostat.: step 6, image 2 of 2
    • The second picture shows the old thermostat after being taken out of the housing.
  7. Ford Mustang Thermostat Replacement, Make sure to put enough sealant around the housing area.: step 7, image 1 of 2 Ford Mustang Thermostat Replacement, Make sure to put enough sealant around the housing area.: step 7, image 2 of 2
    • The pictures show specifically where to apply the sealant.
  8. Ford Mustang Thermostat Replacement, Insert the new thermostat back into its place.: step 8, image 1 of 1
    • Note that if any antifreeze leaked throughout the process of replacing the thermostat, put more antifreeze in the car after you reassemble everything back to normal.
To reassemble the thermostat, follow these steps in reverse order.
Naggle
187 Reputation
1 Guide authored
One Comment
No mostraron como va puesto el sello del termostato.
YEFRI XT SALINAS XW - Reply
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 103
All Time: 8,456
