Fosera Scandle 200 Charging Terminal Replacement
  1. Fosera Scandle 200 Charging Terminal Replacement, Motherboard Removal: step 1, image 1 of 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Charging Terminal Replacement: step 2, image 1 of 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Charging Terminal Replacement: step 3, image 1 of 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Charging Terminal Replacement: step 4, image 1 of 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Charging Terminal Replacement: step 5, image 1 of 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Charging Terminal Replacement, Charging Terminal: step 6, image 1 of 1
    • Use caution when using a soldering iron, the tip will be very hot.
    • Locate the charging terminal's three prong connectors on the back of the motherboard.
  7. Fosera Scandle 200 Charging Terminal Replacement: step 7, image 1 of 1
    • Start melting the solder on each prong connector individually with the soldering iron.
  8. Fosera Scandle 200 Charging Terminal Replacement: step 8, image 1 of 1
    • Use the flat end of the spudger to pry the charging terminal away from the motherboard.
David
127 Reputation
1 Guide authored
USF Tampa, Team 12-5, Blackwell Fall 2014 Member of USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 445
