Fossil Q Marshal Gen 2 Screen Replacement
  1. Fossil Q Marshal Gen 2 Screen Replacement, Back Cover: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Screen Replacement: step 2, image 1 of 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Screen Replacement: step 3, image 1 of 2 Fossil Q Marshal Gen 2 Screen Replacement: step 3, image 2 of 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Screen Replacement: step 4, image 1 of 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 1 of 3 Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 2 of 3 Fossil Q Marshal Gen 2 Screen Replacement: step 5, image 3 of 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Screen Replacement, Screen: step 6, image 1 of 2 Fossil Q Marshal Gen 2 Screen Replacement, Screen: step 6, image 2 of 2
    • The screen can now be removed out of the front-side of the watch.
12 other people completed this guide.
Matthew Tucker
580 Reputation
3 Guides authored
IUPUI, Team S2-G5, Harley Fall 2017 Member of IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Members
6 Guides authored
17 Comments
Where can i find a replacement screen for the founder q 2.0 version?
Jack Seitz - Reply
Where can I buy replacement screen for gen 1
David Aslamazashvili -
Is the screen glued to the bezel of the watch?
Jose - Reply
Hello,
Do you have spare parts for the Fossil Q Marshal gen 2 watch?
Alexis Stellato - Reply
Where can I find a replacement screen for this devise?, I’ve done a little searching but I’m struggling to find someone who sells the replacement parts.
evans.nathan6 - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 43
All Time: 19,020
