Framework Laptop 16" Keyboard Replacement
  1. Framework Laptop 16" Keyboard Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 16" Keyboard Replacement, Before you begin: step 1, image 2 of 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: step 2, image 1 of 3 Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: step 2, image 2 of 3 Framework Laptop 16" Keyboard Replacement, Unlock the Input Modules: step 2, image 3 of 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: step 3, image 1 of 3 Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: step 3, image 2 of 3 Framework Laptop 16" Keyboard Replacement, Remove the touchpad spacers: step 3, image 3 of 3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Keyboard Replacement: step 4, image 1 of 1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Keyboard Replacement, Remove the touchpad: step 5, image 1 of 3 Framework Laptop 16" Keyboard Replacement, Remove the touchpad: step 5, image 2 of 3 Framework Laptop 16" Keyboard Replacement, Remove the touchpad: step 5, image 3 of 3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Keyboard Replacement, Remove the keyboard: step 6, image 1 of 3 Framework Laptop 16" Keyboard Replacement, Remove the keyboard: step 6, image 2 of 3 Framework Laptop 16" Keyboard Replacement, Remove the keyboard: step 6, image 3 of 3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
215,604 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,821 Guides authored
1 Guide Comment
this is a pretty funny guide, i genuinely like that it exists lol, only thing is you dont need to shut down your system; the keyboard, trackpad, numpad/macropad, spacers, LED matrix strips, etc, can be hot-swapped. same with the input modules
ChazIsBuns - Reply
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 90
All Time: 1,511
