Framework Laptop 16" Midframe Replacement
  1. Framework Laptop 16" Midframe Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 16" Midframe Replacement, Before you begin: step 1, image 2 of 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Midframe Replacement, Unlock the Input Modules: step 2, image 1 of 3 Framework Laptop 16" Midframe Replacement, Unlock the Input Modules: step 2, image 2 of 3 Framework Laptop 16" Midframe Replacement, Unlock the Input Modules: step 2, image 3 of 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Midframe Replacement, Remove the touchpad spacers: step 3, image 1 of 3 Framework Laptop 16" Midframe Replacement, Remove the touchpad spacers: step 3, image 2 of 3 Framework Laptop 16" Midframe Replacement, Remove the touchpad spacers: step 3, image 3 of 3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Midframe Replacement: step 4, image 1 of 1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Midframe Replacement, Remove the touchpad: step 5, image 1 of 3 Framework Laptop 16" Midframe Replacement, Remove the touchpad: step 5, image 2 of 3 Framework Laptop 16" Midframe Replacement, Remove the touchpad: step 5, image 3 of 3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Midframe Replacement, Remove the keyboard: step 6, image 1 of 3 Framework Laptop 16" Midframe Replacement, Remove the keyboard: step 6, image 2 of 3 Framework Laptop 16" Midframe Replacement, Remove the keyboard: step 6, image 3 of 3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" Midframe Replacement, Remove the numpad: step 7, image 1 of 3 Framework Laptop 16" Midframe Replacement, Remove the numpad: step 7, image 2 of 3 Framework Laptop 16" Midframe Replacement, Remove the numpad: step 7, image 3 of 3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" Midframe Replacement, Disconnect the midframe cable: step 8, image 1 of 2 Framework Laptop 16" Midframe Replacement, Disconnect the midframe cable: step 8, image 2 of 2
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" Midframe Replacement, Loosen the midframe screws: step 9, image 1 of 2 Framework Laptop 16" Midframe Replacement, Loosen the midframe screws: step 9, image 2 of 2
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" Midframe Replacement, Remove the midframe: step 10, image 1 of 2 Framework Laptop 16" Midframe Replacement, Remove the midframe: step 10, image 2 of 2
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" Midframe Replacement: step 11, image 1 of 2 Framework Laptop 16" Midframe Replacement: step 11, image 2 of 2
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
127,734 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
One Comment
It's not clear if I have to remove the blue tape on the middle frame. Can you help me please?
Enrico - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 92
