Frequency Amplifier Marshall Kilburn Battery Replacement
  1. Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: step 1, image 1 of 3 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: step 1, image 2 of 3 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: step 1, image 3 of 3
    • Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
  2. Frequency Amplifier Marshall Kilburn Battery Replacement: step 2, image 1 of 1
    • Using a TR10 Torx Security Screwdriver, remove the two screws from the door.
    • Remove the door.
  3. Frequency Amplifier Marshall Kilburn Battery Replacement: step 3, image 1 of 3 Frequency Amplifier Marshall Kilburn Battery Replacement: step 3, image 2 of 3 Frequency Amplifier Marshall Kilburn Battery Replacement: step 3, image 3 of 3
    • Pull the yellow tab to remove the battery from the amp.
  4. Frequency Amplifier Marshall Kilburn Battery Replacement: step 4, image 1 of 2 Frequency Amplifier Marshall Kilburn Battery Replacement: step 4, image 2 of 2
    • Carefully disconnect the battery cord from its socket. Carefully pinch the ends of the rectangular battery cord connector that is connected to the machine and gently pull the rectangular portion away from the machine so that it disconnects.
  5. Frequency Amplifier Marshall Kilburn Battery Replacement: step 5, image 1 of 2 Frequency Amplifier Marshall Kilburn Battery Replacement: step 5, image 2 of 2
    • To reassemble, plug in the new battery cord, and insert the battery pack; have the yellow tab repositioned as in step 3.
Edith-Marie Roper
104 Reputation
1 Guide authored
One Comment
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
Adnan Kasumovic - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 93
All Time: 4,375
