Frigidaire FFPE45B2QM Broken Thermostat Replacement
  1. Frigidaire FFPE45B2QM Broken Thermostat Replacement, Broken Thermostat: step 1, image 1 of 1
    • Make sure you unplug refrigerator before beginning work on refrigerator.
  2. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 2, image 1 of 1
    • Remove the 28 mm screw holding the thermostat to the refrigerator using the JIS #1 screwdriver
  3. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 3, image 1 of 1
    • Carefully remove the thermostat knob.
  4. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 4, image 1 of 1
    • Carefully slide off the thermostat towards you.
  5. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 5, image 1 of 1
    • Once the thermostat is removed, take a picture of the cords (still connected) to help with reassembly. Then proceed to disconnect the wires.
  6. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 6, image 1 of 1
    • Remove the three cords on the front side of the thermostat by simply pulling the plastic connector off for two connections and doing the same for the metal connection. Do the same to the back side, disconnecting another plastic connector and then remove the thermostat.
  7. Frigidaire FFPE45B2QM Broken Thermostat Replacement: step 7, image 1 of 1
    • Replace the old thermostat and reassemble the new thermostat using the picture that you took before to properly connect the wires.
4 other people completed this guide.
Peterluchini
556 Reputation
3 Guides authored
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-2, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G2
3 Members
3 Guides authored
3 Comments
Peter, I have the same fridge and it never dropped any colder than 43F. Is this the same issue you were having? Did changing the thermostat fix it?
Thanks!
Krunal Patel - Reply
شما یا درجه ترموستات یخچال را بر روی بیشترین مقدار قرار دهید یا دو سیم ترموستات را به یکدیگر وصل کنید که همواره کمپرسور یخچال روشن بماند و خاموش نشود
بعد از چند ساعت برسی کنید ایا شرمای یخچال مناسب است؟ اگر مناسب بود یعنی ترموستات یخچال ایراد دارد و اگر باز هم سرد نبود مشکل از کم بودن گلز مبرد است و باید گاز سرر کننده تزریق شود
David -
You either set the refrigerator thermostat to the highest value or connect the two thermostat wires to each other so that the refrigerator compressor always stays on and does not turn off.
After a few hours, check if the refrigerator is suitable. If it was suitable, it means that the refrigerator thermostat has a problem, and if it is still not cold, the problem is due to the lack of coolant, and cooling gas should be injected.
David -
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,442
