Frigidaire FFPE45B2QM Refrigerator Door Replacement
  1. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Broken Hinge: step 1, image 1 of 1
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Refrigerator Door Replacement: step 2, image 1 of 1
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Refrigerator Door Replacement: step 3, image 1 of 2 Frigidaire FFPE45B2QM Refrigerator Door Replacement: step 3, image 2 of 2
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  4. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Refrigerator Door: step 4, image 1 of 1
    • Remove the door by slowly lifting straight up, put the door off to the side.
  5. Frigidaire FFPE45B2QM Refrigerator Door Replacement: step 5, image 1 of 1
    • Get a new, non-damaged door.
2 other people completed this guide.
Peterluchini
556 Reputation
3 Guides authored
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-2, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G2
3 Members
3 Guides authored
One Comment
So this is a 4.5 cubic foot mini-refrigerator. I suppose the door was damaged in moving the refrigerator - maybe dropped because it has a weight of 58 pounds.
doctordon - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,441
