Shop the Holiday Gift Guide
Front License Plate Installation
Views: 30K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
182
All Time:
29,732
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Front License Plate Installation, Front License Plate Installation: step 1, image 1 of 3 Front License Plate Installation, Front License Plate Installation: step 1, image 2 of 3 Front License Plate Installation, Front License Plate Installation: step 1, image 3 of 3
      • Gather your tools. Drill, Sharpie, Drill Bits, Painters Tape.
      • Get the parts, too. The front license plate bracket and the 4 plastic spreader rivets.
      • Don't forget the Touareg :)
      • Use Painters Tape to mark your drill bits at 1/2" of depth - so you don't drill into the bumper too far.
      Ask FixBot
    2. Front License Plate Installation: step 2, image 1 of 2 Front License Plate Installation: step 2, image 2 of 2
      • Position the license plate frame and center it on the VW emblem and parking camera (below, if installed). You can use the vertical supports in the lower grill (hard to see in this pic) to assist in alignment.
      • Hold the license plate frame in place using some painters tape.
      • Using the Sharpie, mark the four holes that you'll be drilling.
      Ask FixBot
    3. Front License Plate Installation: step 3, image 1 of 1
      • Remove the frame for easier drilling.
      • Using the 1/8" drill bit, drill four pilot holes in the center of each position.
      • Finish the holes by enlarging them with the 11/32" drill bit.
      Ask FixBot
    4. Front License Plate Installation: step 4, image 1 of 2 Front License Plate Installation: step 4, image 2 of 2
      • Place the frame back into position.
      • Install the four plastic spreader rivets.
      • Ensure they are seated by using a socket (as shown) to ensure rivets are fully seated before pushing in the center pin.
      Ask FixBot
    5. Front License Plate Installation: step 5, image 1 of 3 Front License Plate Installation: step 5, image 2 of 3 Front License Plate Installation: step 5, image 3 of 3
      • Tap the center pins of the rivets so they are flush with the rivet body.
      • Use #10 x 1/2" Stainless Steel Screws to affix the plate to the mounting bracket. You can see slight indentations where the screws are to go. I drilled pilot holes first.
      • Don't use the "standard" license plate hardware that is 3/4" long. Those screws appear to be long enough to hit the bumper when inserted.
      Ask FixBot
Finish Line
8 other people completed this guide.
Justin
1,595 Reputation
3 Guides authored
6 Guide Comments
I would like to know where the license plate bracket/frame was purchased.
ruthkoljonen - Reply Share
Nice instructions! I bought my Touareg from Honda dealer with no front plate holder. They ordered me the holder but it came with no instructions. These were perfect! Thank you!!!
TRENT MATTHEWS - Reply Share
Really, VW. $45,000+ for an ID.4 and *I* have to drill holes in the body to mount the license. This stinks.
E F Charles LaBerge - Reply Share
Utter bullshit that this is my task
XXX - Reply Share
This was immensely helpful and the install went seamlessly. THANK YOU JUSTIN!
I had to go buy an 11/32 bit but that was definitely a perfect size for those plastic rivets.
FYI - if anyone is wondering you need to get the part from your VW Dealer, not from some aftermarket/Amazon outfit. Mine was made in Slovakia same as the car and it fit perfectly.
...and yes, my car was from Alberta, Canada and they only use one plate because they are the renegade province of Canada!!
604Pete - Reply Share
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 182
All Time: 29,732
