Front Panel Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Front Panel Assembly Replacement: step 2, image 1 of 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Front Panel Assembly Replacement: step 3, image 1 of 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Front Panel Assembly Replacement: step 4, image 1 of 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Front Panel Assembly Replacement: step 5, image 1 of 2 Front Panel Assembly Replacement: step 5, image 2 of 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Front Panel Assembly Replacement: step 6, image 1 of 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Front Panel Assembly Replacement: step 7, image 1 of 2 Front Panel Assembly Replacement: step 7, image 2 of 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
Carlos Salas
194 Reputation
1 Guide authored
USF Tampa, Team 4-6, Passmore Fall 2016 Member of USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 107
