Introduction
Remove and replace a turn signal bulb on the third-generation Dodge Ram 1500.
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
Unscrew the second screw located approximately 6 inches below the first.
Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
Turn the turn signal bulb holder counterclockwise until it stops.
Remove the bulb holder.
Inspect the bulb. Check for broken filaments or cracked glass.
To reassemble the headlight assembly, follow these instructions in reverse order.
6 other people completed this guide.
4 Guide Comments
WRONG! Just reach around behind and pop the bulb out. This is A LOT of unnecessary steps for absolutely NO REASON.
haha…try that on my 2007! Drivers side is impossible to reach. gotta take the whole light fixture.
How do you change left side FRONT turn signal bulb on a 2011 CHRYSLER 200
no way you can change my CHRYSLER 2011 200 model this way
