Fugoo Tough Power Button Replacement
  1. Fugoo Tough Power Button Replacement, Power Button: step 1, image 1 of 3 Fugoo Tough Power Button Replacement, Power Button: step 1, image 2 of 3 Fugoo Tough Power Button Replacement, Power Button: step 1, image 3 of 3
    • Begin by unscrewing the four 10.72 mm corner screws using the Hex 2.0 screwdriver.
    • Using the Hex 1.5 screwdriver, remove the remaining six 5.79 mm screws on the front of the speaker.
    • Pull the front part of shell away from the back part of shell.
  2. Fugoo Tough Power Button Replacement: step 2, image 1 of 3 Fugoo Tough Power Button Replacement: step 2, image 2 of 3 Fugoo Tough Power Button Replacement: step 2, image 3 of 3
    • Change to the h1.3 head. Remove all four 5.57mm screws on both speaker covers.
    • Pull on the speaker covers to remove them.
    • Rotate the speaker 180 degrees and then remove the four 5.57 mm screws on the side speaker that has the power/bluetooth buttons.
    • Pull apart the side speaker and its casing away from the body of the Fugoo.
  3. Fugoo Tough Power Button Replacement: step 3, image 1 of 2 Fugoo Tough Power Button Replacement: step 3, image 2 of 2
    • After pulling apart the side speaker and its casing, you will see both the power and Bluetooth buttons on the underside of the circuit board.
    • Desolder the power button and replace it on the motherboard.
2 Comments
Where can I buy the screwdrivers to remove the 4-5.57mm screws?
Frank Peñalo - Reply
Where can you find/source replacement power switches?
ginj - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 467
