FujiFilm FinePix A340 Flash Unit Replacement
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: step 1, image 1 of 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: step 2, image 1 of 3 FujiFilm FinePix A340 Flash Unit Replacement: step 2, image 2 of 3 FujiFilm FinePix A340 Flash Unit Replacement: step 2, image 3 of 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: step 3, image 1 of 2 FujiFilm FinePix A340 Flash Unit Replacement: step 3, image 2 of 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: step 4, image 1 of 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: step 5, image 1 of 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: step 6, image 1 of 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: step 7, image 1 of 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: step 8, image 1 of 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: step 9, image 1 of 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: step 10, image 1 of 2 FujiFilm FinePix A340 Flash Unit Replacement: step 10, image 2 of 2
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: step 11, image 1 of 2 FujiFilm FinePix A340 Flash Unit Replacement: step 11, image 2 of 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: step 12, image 1 of 2 FujiFilm FinePix A340 Flash Unit Replacement: step 12, image 2 of 2
    • Remove the logic board by pulling straight away from assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: step 13, image 1 of 1
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: step 14, image 1 of 2 FujiFilm FinePix A340 Flash Unit Replacement: step 14, image 2 of 2
    • Unsolder the flash unit at it's three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
Cody
47 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Spring 2010 Member of Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 3,919
