FujiFilm FinePix S4500 LCD Replacement
  1. FujiFilm FinePix S4500 LCD Replacement, LCD: step 1, image 1 of 1
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 LCD Replacement: step 2, image 1 of 1
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 LCD Replacement: step 3, image 1 of 1
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 LCD Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 LCD Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 LCD Replacement: step 6, image 1 of 2 FujiFilm FinePix S4500 LCD Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 LCD Replacement: step 7, image 1 of 1
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 LCD Replacement: step 8, image 1 of 2 FujiFilm FinePix S4500 LCD Replacement: step 8, image 2 of 2
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
Vicente Rios
708 Reputation
6 Guides authored
Cal Poly, Team 9-4, Banghart Winter 2017 Member of Cal Poly, Team 9-4, Banghart Winter 2017
CPSU-BANGHART-W17S9G4
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 617
