FujiFilm FinePix XP10SE Lens Replacement
  1. FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 1 of 3 FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 2 of 3 FujiFilm FinePix XP10SE Lens Replacement, Front Cover: step 1, image 3 of 3
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  2. FujiFilm FinePix XP10SE Lens Replacement: step 2, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to detach the case.
  3. FujiFilm FinePix XP10SE Lens Replacement: step 3, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  4. FujiFilm FinePix XP10SE Lens Replacement: step 4, image 1 of 3 FujiFilm FinePix XP10SE Lens Replacement: step 4, image 2 of 3 FujiFilm FinePix XP10SE Lens Replacement: step 4, image 3 of 3
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
  5. FujiFilm FinePix XP10SE Lens Replacement, Lens: step 5, image 1 of 1
    • Remove the screws from the lens cover
  6. FujiFilm FinePix XP10SE Lens Replacement: step 6, image 1 of 1
    • Remove the screws from the side metal cover of outer case.
  7. FujiFilm FinePix XP10SE Lens Replacement: step 7, image 1 of 2 FujiFilm FinePix XP10SE Lens Replacement: step 7, image 2 of 2
    • Gently remove the Lens from the housing.
Bryan
598 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 189
