Fujifilm Endeavor 100ix Battery Door Replacement
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: step 1, image 1 of 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: step 2, image 1 of 1
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: step 3, image 1 of 1
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: step 4, image 1 of 1
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: step 5, image 1 of 1
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: step 6, image 1 of 1
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: step 7, image 1 of 2 Fujifilm Endeavor 100ix Battery Door Replacement: step 7, image 2 of 2
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
Eric Nicolai
679 Reputation
6 Guides authored
Cal Poly, Team 13-5, Forte Winter 2011 Member of Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,889
