Fujifilm Fine S1800 LCD Screen Replacement
Ryan Rockford
Ryan Rockford and 8 other contributors
Last updated on January 5, 2024
20 - 25 minutes
Moderate
Better Introduction
Introduction
Go to step 1
This guide explains how to replace the old broken LCD screen.
Tools
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: step 1, image 1 of 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: step 2, image 1 of 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: step 3, image 1 of 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: step 4, image 1 of 2 Fujifilm Fine S1800 LCD Screen Replacement: step 4, image 2 of 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: step 5, image 1 of 2 Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: step 5, image 2 of 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: step 6, image 1 of 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: step 7, image 1 of 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
Ryan Rockford
618 Reputation
5 Guides authored
USF Tampa, Team 8-6, Eyestone Spring 2017 Member of USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 595
