Fujifilm FinePix 4700 Zoom Battery Compartment Replacement
  1. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement, Back Cover: step 1, image 1 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement, Back Cover: step 1, image 2 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement, Back Cover: step 1, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 2, image 1 of 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 3, image 1 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 3, image 2 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 3, image 3 of 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 4, image 1 of 2 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 4, image 2 of 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 5, image 1 of 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
  6. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement, Motherboard Unit: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Pull gently when removing the speaker so you don't rip the wire attached to it.
    • Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
    • The speaker will still be connected to the motherboard, but it will not be attached to the front case.
  7. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 7, image 1 of 1
    • Use the tweezers to pull gently on the small orange ribbon, located in upper left hand corner near the flash, to remove the square insert.
  8. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 8, image 1 of 1
    • Use your fingers to slowly pull the flash straight up.
    • The step may take a little jiggling.
  9. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 9, image 1 of 2 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 9, image 2 of 2
    • Do not fully separate the motherboard unit from the front cover. There is still a ribbon attached and it will rip.
    • Slightly separate the front cover from the motherboard unit (which consists of the motherboard, speaker, screen, and battery compartment).
    • Rotate the bottom portion of the motherboard unit (the screen and battery compartment) over the lens unit.
  10. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 10, image 1 of 1
    • Use your fingers to remove the tripod mount.
  11. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 11, image 1 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 11, image 2 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 11, image 3 of 3
    • Be gentle when undoing the ribbon clips. They break easily.
    • Gently stick the spudger under the ribbon clips and lift them up.
    • Use the tweezers to pull both ribbons out of the ribbon clips.
    • The motherboard unit should now be free from the rest of the camera.
  12. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement, Battery Compartment: step 12, image 1 of 1
    • Locate the wires running from the battery compartment to the main motherboard.
    • There are two sets of black and red wires.
  13. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 13, image 1 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 13, image 2 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 13, image 3 of 3
    Buy
    • Use the tweezers to grab one set of wires near where it connects to the motherboard.
    • Pull the set of wires straight out.
    • Repeat these steps for the other set of wires.
  14. Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 14, image 1 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 14, image 2 of 3 Fujifilm FinePix 4700 Zoom Battery Compartment Replacement: step 14, image 3 of 3
    • Lift and pull outward (at the same time) the two battery clips that are next to the screen.
    • The battery compartment should now be detached from the rest of the motherboard unit.
Lawrence Yang
14 Reputation
3 Guides authored
Cal Poly, Team 14-8, Forte Spring 2012 Member of Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
5 Members
17 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 2,130
