Fujifilm FinePix A350 Battery Contact Replacement
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: step 1, image 1 of 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: step 1, image 2 of 3 Fujifilm FinePix A350 Battery Contact Replacement, Batteries: step 1, image 3 of 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: step 2, image 1 of 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: step 2, image 2 of 3 Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: step 2, image 3 of 3
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Jaxon Cramer
1,045 Reputation
9 Guides authored
Clemson, Team 6-4, Benson Spring 2016 Member of Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Members
17 Guides authored
One Comment
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 494
