Fujifilm FinePix A350 Memory Card Replacement
  1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: step 1, image 1 of 3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: step 1, image 2 of 3 Fujifilm FinePix A350 Memory Card Replacement, Batteries: step 1, image 3 of 3
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: step 2, image 1 of 3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: step 2, image 2 of 3 Fujifilm FinePix A350 Memory Card Replacement, Memory Card: step 2, image 3 of 3
    • Locate the memory card in the long, thin slot above the battery compartment.
    • Using your thumb, push the memory card farther into the camera.
    • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
Jaxon Cramer
1,045 Reputation
9 Guides authored
Clemson, Team 6-4, Benson Spring 2016 Member of Clemson, Team 6-4, Benson Spring 2016
CLEM-BENSON-S16S6G4
4 Members
17 Guides authored
One Comment
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
oli.ber - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 68
All Time: 1,189
