Fujifilm FinePix AX665 Battery Door Hinge Replacement
  1. Fujifilm FinePix AX665 Battery Door Hinge Replacement, Battery Door Hinge: step 1, image 1 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement, Battery Door Hinge: step 1, image 2 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement, Battery Door Hinge: step 1, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the six screws around the camera in order to be able to remove the case.
    • Slide the battery door to the unlocked position
  2. Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 2, image 1 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 2, image 2 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 2, image 3 of 3
    • Use a plastic pick to separate each side of the camera case apart
  3. Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 3, image 1 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 3, image 2 of 3 Fujifilm FinePix AX665 Battery Door Hinge Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Put the tweezers in one end where the bar that connects the battery door to the body of the camera so that the end of the bar sticks out.
    • Remove this metal bar and replace with new one if damaged
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 27
All Time: 538
