Fujifilm FinePix AX665 Sensor Replacement
  1. Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 1 of 3 Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 2 of 3 Fujifilm FinePix AX665 Sensor Replacement, Sensor: step 1, image 3 of 3
    • Use a #00 Phillips screwdriver to remove all six screws around the camera that is holding the case.
  2. Fujifilm FinePix AX665 Sensor Replacement: step 2, image 1 of 3 Fujifilm FinePix AX665 Sensor Replacement: step 2, image 2 of 3 Fujifilm FinePix AX665 Sensor Replacement: step 2, image 3 of 3
    • Use a plastic pick to separate each side of the camera case apart.
  3. Fujifilm FinePix AX665 Sensor Replacement: step 3, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 3, image 2 of 2
    • Remove the ribbon cable from the side of logic board.
  4. Fujifilm FinePix AX665 Sensor Replacement: step 4, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 4, image 2 of 2
    • Remove the four metal clips around the camera until you can feel the metal bracket that holds the screen pop off.
  5. Fujifilm FinePix AX665 Sensor Replacement: step 5, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 5, image 2 of 2
    • Carefully flip the screen and remove the ribbon cable attaching it to the logic board.
  6. Fujifilm FinePix AX665 Sensor Replacement: step 6, image 1 of 1
    • Remove the three screws holding the sensor.
  7. Fujifilm FinePix AX665 Sensor Replacement: step 7, image 1 of 2 Fujifilm FinePix AX665 Sensor Replacement: step 7, image 2 of 2
    • Remove the sensor ribbon cable from the logic board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 455
