Fujifilm FinePix F505EXR LCD monitor Replacement
  1. Fujifilm FinePix F505EXR LCD monitor Replacement, Battery: step 1, image 1 of 2 Fujifilm FinePix F505EXR LCD monitor Replacement, Battery: step 1, image 2 of 2
    • Power the device down before taking any other actions.
    • Hold the camera with the lens facing towards youself.
    • Turn the camera upside down and place your right thumb on the battery chamber cover.
  2. Fujifilm FinePix F505EXR LCD monitor Replacement: step 2, image 1 of 2 Fujifilm FinePix F505EXR LCD monitor Replacement: step 2, image 2 of 2
    • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
    • Pull the cover entirely out and release it to reveal the battery.
  3. Fujifilm FinePix F505EXR LCD monitor Replacement: step 3, image 1 of 2 Fujifilm FinePix F505EXR LCD monitor Replacement: step 3, image 2 of 2
    • Locate the orange battery latch that holds the battery in place.
    • Use your finger to push the latch away from yourself to release the battery.
    • Remove the battery manually from the battery chamber.
    • Place the battery into a charger if it is dead.
    • Remove battery before performing any other repairs.
    • Replace defective battery if previous steps fail
    • Contact support on the Fujifilm website for further assistance
  4. Fujifilm FinePix F505EXR LCD monitor Replacement, Selector Button Circuit Board: step 5, image 1 of 3 Fujifilm FinePix F505EXR LCD monitor Replacement, Selector Button Circuit Board: step 5, image 2 of 3 Fujifilm FinePix F505EXR LCD monitor Replacement, Selector Button Circuit Board: step 5, image 3 of 3
    • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
    • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
    • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
  5. Fujifilm FinePix F505EXR LCD monitor Replacement: step 6, image 1 of 2 Fujifilm FinePix F505EXR LCD monitor Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
    • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
    • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
    • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
    • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
  6. Fujifilm FinePix F505EXR LCD monitor Replacement: step 7, image 1 of 1
    • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
    • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
  7. Fujifilm FinePix F505EXR LCD monitor Replacement: step 8, image 1 of 3 Fujifilm FinePix F505EXR LCD monitor Replacement: step 8, image 2 of 3 Fujifilm FinePix F505EXR LCD monitor Replacement: step 8, image 3 of 3
    • Lift the chip with tweezers to remove it from the other remaining components.
  8. Fujifilm FinePix F505EXR LCD monitor Replacement, LCD monitor: step 9, image 1 of 1
    Buy
    • With the LCD monitor facing upwards, use the tweezers to lift the ribbon clamp which will release the grip on the ribbon.
    • Failure to do this can result in major damage to the connection.
  9. Fujifilm FinePix F505EXR LCD monitor Replacement: step 10, image 1 of 1
    • With the tweezers pull the ribbon away from the connector, freeing it and allowing it to move.
  10. Fujifilm FinePix F505EXR LCD monitor Replacement: step 11, image 1 of 1
    • With your fingers around the edges of the LCD monitor, lift it away from the camera.
Brittany Perkins
310 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 365
