Fujifilm FinePix HS30EXR Frame Replacement
  1. Fujifilm FinePix HS30EXR Frame Replacement, Frame: step 1, image 1 of 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Frame Replacement: step 2, image 1 of 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Frame Replacement: step 3, image 1 of 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Frame Replacement: step 4, image 1 of 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Frame Replacement: step 5, image 1 of 1
  6. Fujifilm FinePix HS30EXR Frame Replacement: step 6, image 1 of 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Frame Replacement: step 7, image 1 of 2 Fujifilm FinePix HS30EXR Frame Replacement: step 7, image 2 of 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
Andrew Scouten
838 Reputation
5 Guides authored
Baylor, Team S1-G2, Williams Fall 2018 Member of Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 712
