Fujifilm FinePix HS30EXR Motherboard Replacement
  1. Fujifilm FinePix HS30EXR Motherboard Replacement, Frame: step 1, image 1 of 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Motherboard Replacement: step 2, image 1 of 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Motherboard Replacement: step 3, image 1 of 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Motherboard Replacement: step 4, image 1 of 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Motherboard Replacement: step 5, image 1 of 1
  6. Fujifilm FinePix HS30EXR Motherboard Replacement: step 6, image 1 of 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Motherboard Replacement: step 7, image 1 of 2 Fujifilm FinePix HS30EXR Motherboard Replacement: step 7, image 2 of 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Motherboard Replacement: step 9, image 1 of 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Motherboard Replacement: step 10, image 1 of 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Motherboard Replacement: step 11, image 1 of 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Motherboard Replacement: step 12, image 1 of 1
  13. Fujifilm FinePix HS30EXR Motherboard Replacement: step 13, image 1 of 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Motherboard Replacement: step 14, image 1 of 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Motherboard Replacement: step 15, image 1 of 1
    • Remove the motherboard.
Andrew Scouten
838 Reputation
5 Guides authored
Baylor, Team S1-G2, Williams Fall 2018 Member of Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Members
12 Guides authored
2 Comments
have you instructions to remove power on and selector assembly?
renato.ciccone - Reply
have you istructions to remove the poweron switch asm. for the hs30exr?
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,218
